Dye Hyper 3 help
6 replies to this topic
#1 zecrom_89
zecrom_89
  • 787 posts
Posted 15 February 2014 - 03:22 PM
I can't get my reg apart. The previous user probably hasn't matienced it yet so its kinda stuck together. I don't want scratch the anno.
#2 Old Dude PB
Old Dude PB
    Safety third.
  • 1,642 posts
Posted 15 February 2014 - 03:29 PM
Pretty common with Dye regs. Try a strap wrench, or of you don't have one, lots of padding and a vice.
#3 zecrom_89
zecrom_89
  • 787 posts
Posted 15 February 2014 - 03:51 PM
what kind of padding? Like a mouse pad?
EDIT: I got the bottom piece off, but the collar wont come off.
Edited by zecrom_89, 15 February 2014 - 04:04 PM.
#4 Old Dude PB
Old Dude PB
    Safety third.
  • 1,642 posts
Posted 15 February 2014 - 04:24 PM
A mouse pad could work.
#5 zecrom_89
zecrom_89
  • 787 posts
Posted 15 February 2014 - 04:31 PM
Alright I had to unscrew the fitting to get the collar off. Thansk for the help Old Dude PB!
#6 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,901 posts
Posted 17 February 2014 - 10:25 PM
Look inside each ends.  You use allen keys and do a quick snap.
#7 zecrom_89
zecrom_89
  • 787 posts
Posted 17 February 2014 - 11:52 PM
Yeah, I found that out. Thanks though!
