Ok guys, I need some autococker custom help
#1 ANGRYPAINTBALL35
ANGRYPAINTBALL35
    Well that didn't work...
  • 115 posts
Posted 16 February 2014 - 01:14 PM
Some of you may remember that earlier in the year I posted pictures of a paintball marker that I needed help identifying. You guys told me it was an autococker trilogy and and I really appreciated the help because it led to my first custom project. I decided to make a pump out of it and I have included some pictures of what I have so far, but I would like to do more. Specifically, I would like to get some of it custom milled and then re anodized. So if you guys know of a company or a person (or even not a person) that will be willing to do some custom work on my marker let me know. Since this is my first time I would like all the recommendations I can get. Thanks!!!!!
http://i807.photobuc...zpsa426ecd6.jpg
http://i807.photobuc...zps202d69f9.jpg
http://i807.photobuc...zps851e70c0.jpg
http://i807.photobuc...zpsdf53f7e0.jpg
http://i807.photobuc...zpse9cfb245.jpg
http://i807.photobuc...zps1f12a8e5.jpg
http://i807.photobuc...zps9bd503c0.jpg
http://i807.photobuc...zps64525aa1.jpg
Nope it's a spyder...
#2 bowmasta
bowmasta
  • 451 posts
Posted 16 February 2014 - 09:43 PM
There aren't to many people custom milling these days. There isn't really that much on a trilogy to mill, Plus it'll cost you quite the pretty penny.
I'v never had milling work done so I don't know.
Anodizing is another thing though there are tons of guys out there doing it.
Caustic Customs does amazing work but is pretty expensive.
Tonsixers is good as well but I don't think they are taking work.
I've heard a lot of people talk about Pooty on PBN.
You may want consider powder coating as well.
Some people say there is a huge weight difference; there really isn't, and powder coat can make effects anodizing never can.
#3 ANGRYPAINTBALL35
ANGRYPAINTBALL35
  • 115 posts
Posted 16 February 2014 - 11:27 PM
Well, I'm mostly going for a milled down feedneck so I can put on a planet eclipse clamping feedneck or something of that style. I have looked into caustic for ano. He is definitely the way I would like to go because of the quality of his work. Thanks for the help man!
