G6R shooting problems
10 replies to this topic
#1 pb2332
pb2332
  • 124 posts
Posted 18 February 2014 - 03:07 PM
Hey I have purchases a used g6r and went to use it for the first time but it wouldn't shoot, it aired up fine with no leaks, when I got home I aired it up again and turned the eyes off and it started shooting rapidly with one trigger pull anyone know what's causing this?
Edited by pb2332, 18 February 2014 - 03:08 PM.
#2 BurningPlaydoh
Posted 18 February 2014 - 04:27 PM
Back out the trigger activation point screw some and make sure the microswitch clicks every time you pull the trigger
#3 tallsmallboy44
Posted 18 February 2014 - 10:35 PM
Make sure your trigger has a return spring or magnet.
#4 pb2332
pb2332
  • 124 posts
Posted 01 March 2014 - 06:42 PM
I tried your solutions and its still doing it, it has the return spring and I can hear/ feel the microswitch, any other solutions
#5 Pvlacrosse14
Pvlacrosse14
    Indians Football OG #67
  • 2,637 posts
Posted 01 March 2014 - 08:06 PM
Try putting in a new battery and resetting the board to factory settings
#6 tallsmallboy44
Posted 01 March 2014 - 09:25 PM
Have you tried upping the debounce, and AMB settings?
#7 pb2332
pb2332
  • 124 posts
Posted 02 March 2014 - 05:23 PM
I already switched the battery with a new Duracell, and reset the board, Ill check the denounce, what setting is the AMB?
#8 tallsmallboy44
Posted 02 March 2014 - 06:34 PM
AMB is the anti-mechanical bounce setting. Allows the user to adjust the anti-mechanical  bounce feature. Mechanical bounce occurs due to the kick generated during each  shot and can cause the marker to “run away” on the first few shots. AMB helps stop markers from going full-auto when the trigger is pulled very slowly. The default is 2 and may be set from 1 to 5 (1 being off). AMB is only used in fire modes 1 and 2 (semi-automatic unlimited and adjustable).
#9 pb2332
pb2332
  • 124 posts
Posted 02 March 2014 - 10:12 PM
Weird that I've never heard of it, thanks a lot for the detailed description I'm gonna look at that right away, thanks again
#10 pb2332
pb2332
  • 124 posts
Posted 03 March 2014 - 09:43 AM
Still doing it, tried it on all parameters of the settings you suggested me to adjust, and its still doing it, I don't understand
#11 tjmartin37661
tjmartin37661
  • 31 posts
Posted 19 March 2014 - 12:25 PM
this had happened to me and all i had to do was increase my debouce setting.  this might be a stupid question but is your firing mode on something like full auto
