Problem with axe?
#1 meh
meh
    Screw you guys, I'm goin' home
  • 231 posts
Posted 23 February 2014 - 09:19 PM
So i was cleaning my axe, and naturally the first thing i went to do was lube the bolt assembly. When i pushed the bottom and worked through the maze to take the bolt assembly out, only the bolt guide came out, and the bolt and the spring stayed inside, and i was forced to stick my finger in through the feedneck and pop it out. I left my axe alone after that for like a day, came back to it ( bolt assembly inside the gun) and it happened again... is this normal? Guns clean and everythings lubed up....Thanks
Meh
If you're under 18 and pay for your own stuff, put this in your signature.
  • 22,424 posts
Posted 23 February 2014 - 09:21 PM
It's perfectly normal for the bolt to not come out with the rest of the engine just from pulling it out the back.
#3 meh
meh
  • 231 posts
Posted 23 February 2014 - 09:26 PM
cool thx
Edited by meh, 23 February 2014 - 09:26 PM.
Meh
#4 PBDream
PBDream
  • 84 posts
Posted 24 February 2014 - 03:55 PM
Happens with my extcy all the time.
#5 pbbrybry
pbbrybry
  • 97 posts
Posted 25 February 2014 - 01:23 AM
I thought the same thing when I first got my marker. but then I upgraded to the boss bolt, the bolt would fall out but the spring would stay. Then I looked at it closely and nothing really attaches with the bolt guide so it made sense.
FEEDBACK!
2 | 0 | 0
