FPS problems with my Invert Mini
Invert Mini FPS
7 replies to this topic
#1 maman3135
maman3135
  • 7 posts
Posted 12 March 2014 - 04:50 PM
Hey guys,
So recently I bought a new Invert Mini (used). Right away I noticed the gun was shooting well under 200 fps so I started cranking it up. For some reason, the gun does not let me increase it any more than 250. Every time i try to make it go higher, air starts to leak out from the velocity screw. Any help or opinion is appreciated.
Thank you,
Maman3135
It doesn't matter what you think, it doesn't matter what you know. All that matters is what you do.
#2 smurfinator22
smurfinator22
  • 710 posts
Posted 12 March 2014 - 05:28 PM
what pressure does the gauge on your asa read?
#3 maman3135
maman3135
  • 7 posts
Posted 12 March 2014 - 06:25 PM
I believe 200, but if that doesn't seem right  I probably didn't understand the question :/
#4 Frisky Tugboat
Frisky Tugboat
    Purple is my favorite animal in the alphabet
  • 1,024 posts
Posted 13 March 2014 - 07:20 AM
Did you check all the O-rings? That's usually the go to for air leaks
Empire Axe, Invert Halo Too, Ninja 50/4500
#5 Carolus Rex
Carolus Rex
    I won at life once.
  • 800 posts
Posted 13 March 2014 - 07:37 AM
Put a new battery in the gun and do a factory reset of the board.
#6 tallsmallboy44
Posted 13 March 2014 - 02:20 PM
Have you tried adjusting the velocity through the back cap on the bolt engine?
#7 XGC_Cheevo
XGC_Cheevo
    Pod Scalping You
  • 3,026 posts
Posted 14 March 2014 - 08:44 AM
That's whats leaking according to the OP.  If you turn the screw out too far for adjusting velocity it will start leaking.  Here's where you have to increase the pressure using the reg.  Now if that pressure is above 200 you have a chance to blow your solenoid.
I would first tear down the marker to make sure you don't have any leaks, clean and re-lube without over lubing, and re-assemble using a new battery and factory settings on the board.  Air it up start trying the marker with the reg pressure around 190 and backing out the velocity screw.
#8 maman3135
maman3135
  • 7 posts
Posted 16 March 2014 - 09:01 PM
Thank you. Ill definitely try this later today
