need first pump advice
help
#1 sorawiz23
sorawiz23
    the ref is here
  • 101 posts
Posted 17 April 2014 - 08:16 AM
i am thinking about getting my first pump so i can play big games cheeper. i need some help because i only have around $200 to spend. i already have hopper and tank so i just need the gun.
Edited by sorawiz23, 17 April 2014 - 08:16 AM.
OH MY GOD THEY'VE GOT ION'S RUN!!!!!!!!
IFyouAREunder18andYOUpayFORyourGEARputTHISinYOURsig
#2 SOUP
SOUP
  • 7,723 posts
Posted 17 April 2014 - 10:39 AM
 I picked up a sweet WGP STO for $200. Great pump, I'll be using it a lot now. I'd say go for either a sniper or a CCI phantom. It just depends on what you're looking for in a pump marker. The phantom will be great for stock class or modified setups and the sniper will be better for open class.
---Indiana Baller---
#3 smurfinator22
smurfinator22
  • 710 posts
Posted 17 April 2014 - 10:40 AM
take a look at the azodin kaos pump if you want to buy new
if you're willing to buy used, take a look at the BST on here or other forums like MCB for used cocker pumps.
#4 sorawiz23
sorawiz23
    the ref is here
  • 101 posts
Posted 17 April 2014 - 12:29 PM
thanks for the help
#5 plan_b
plan_b
  • 367 posts
Posted 18 April 2014 - 08:13 AM
for an inexpensive option is the empire trracer with a bottom line kit.  the bottom line kit is a personal preference, but it makes it easier to sight down range.  or if you find some sort of sniper for around the same price, it would be a very good option as well.
what kind of gun are you playing with right now?
Also tagged with one or more of these keywords: help
