ion leaking please help!
#1 sorawiz23
sorawiz23
    the ref is here
  • 101 posts
Posted 05 May 2014 - 12:17 PM
hi i have a ion and it is leaking from the internals. no tubes are not punched. screws are tightened down and it is still leaking. i have re-lubed it and pushed the tubes back into the connections. i have no idea how to fix it and it is my only electro and i need it to work....
OH MY GOD THEY'VE GOT ION'S RUN!!!!!!!!
IFyouAREunder18andYOUpayFORyourGEARputTHISinYOURsig
  • 22,432 posts
Posted 05 May 2014 - 12:20 PM
Have you aired it up with the grip frame off the gun so you can pinpoint the spot of the leak?
#3 sorawiz23
sorawiz23
    the ref is here
  • 101 posts
Posted 09 May 2014 - 10:40 AM
i think it was near the eye wire but not 100% positive but that is where i think it is
#4 sorawiz23
sorawiz23
    the ref is here
  • 101 posts
Posted 14 May 2014 - 08:05 AM
the leak is fixed now just had to loosen some screws and move the eye wire.
