g6r, problem with setting pressures
10 replies to this topic
#1 pb2332
pb2332
  • 124 posts
Posted 06 May 2014 - 11:30 PM
Hey I have my first bob long g6r and I'm new to setting pressures on a marker. I can't seem to find the spot where my marker shoots normal. Balls either roll out the barrel or it shoots at 340 fps. It's with the lp poppet and I set my pressures to 75 on the lpr and 185 on the hpr, any suggestions on whats wrong?
  • 22,435 posts
Posted 06 May 2014 - 11:38 PM
Stock settings on the board?
#3 pb2332
pb2332
  • 124 posts
Posted 06 May 2014 - 11:50 PM
Yes sir as well as fresh battery
#4 Cyk101
Cyk101
  • 155 posts
Posted 07 May 2014 - 12:42 AM
Lurker method of sweetspotting regs.
1: Back out both regs or Zero out both the LPR and HPR to 0psi
2: Raise HPR slightly only to set LPR for cycling
3: Raise LPR to fully cycling ~45psi or so
4: Raise HPR until velocity begins to stop rising as you increase pressure
5: Raise LPR to desired velocity
6: Lower HPR a bit, then raise if necessary... you're trying to find the best HPR setting at the LPR setting you have. This may put your velocity over 300/285
7: Lower LPR slightly to field velocity
#5 pb2332
pb2332
  • 124 posts
Posted 07 May 2014 - 08:13 AM
I'll give it a try when I go paintballing tonight thank you
#6 XGC_Cheevo
XGC_Cheevo
    Pod Scalping You
  • 3,026 posts
Posted 07 May 2014 - 08:50 AM
With the LP poppit your marker will perform completely different than stock settings.  Like what was said above, you'll have to do a custom tune.
#7 pb2332
pb2332
  • 124 posts
Posted 07 May 2014 - 03:54 PM
Ok I understand that but it seems like the bolt won't go foward enough to strike the ball properly and I can't get readings from the chrono graph
#8 andrewthewookie
  • 22,435 posts
Posted 07 May 2014 - 04:45 PM
With stock board settings, what you'll want to do is turn your LPR up from nil until you get a consistent reading over the chrono. It doesn't matter what the HPR is at as long as it's in the ballpark of typical FPS, then once you've reached a consistent shot, use the HPR to chrono the gun to your field's limits.
#9 BurningPlaydoh
Posted 07 May 2014 - 05:55 PM
Your reg or regs are too low, your tank is facked, the schraders are toast (at least I think low velocity is a symptom of that) or a couple other things could be the cause
#10 XGC_Cheevo
XGC_Cheevo
    Pod Scalping You
  • 3,026 posts
Posted 07 May 2014 - 09:31 PM
Using the lurker method you start with your regs at zero.  I'm guessing one or both of them isnt set high enough.
#11 pb2332
pb2332
  • 124 posts
Posted 08 May 2014 - 08:38 AM
Using the method I got it shooting 290 fps but it kicked worse than my etek 4 which isn't normal. I might just go back to the regular poppet and see if that changes anything
