Smart parts ion
7 replies to this topic
#1 Jake45
Jake45
  • 1 posts
Posted 04 July 2014 - 03:29 PM
Hi I'm new to paint ball and want to know if the smart parts ion is a good marker to use I have an a5 but the fields I play at are more like speed ball with barrels and small bunkers any help with this or finding ungrades for the ion would be great thank you
#2 Forrest99
Forrest99
    2spooky4u
  • 413 posts
Posted 05 July 2014 - 02:11 PM
you can get much better guns for ion price, like an 07 PMR
Any one with a B2k pds board?
#3 tallsmallboy44
Posted 05 July 2014 - 05:56 PM
So, a Dye Ion?
#4 tcheekdye
tcheekdye
    Bitch im just bustin at em
  • 783 posts
Posted 05 July 2014 - 10:23 PM
The ion is fine, just expect shitty resale value
giphy.gifTECH PB HEAVY METAL FAN CLUB  http://www.techpb.co...metal-fan-club/
#5 Lotus
Lotus
    Tech Guy
  • 4,930 posts
Posted 05 July 2014 - 10:32 PM
The Ion is shit in every way except its internal operation.
1) You have to completely take apart the marker (body off frame, unscrew the body in half) in order to do regular maintenance and to clean out a chop.
2) It has a trash feedneck that won't fit most loaders
3) It has a dogshit board
4) It has a dogshit trigger
5) It has dogshit ergonomics
Basically, you can make an Ion great, but you won't be using any of the original parts. Most important is an Xe body, or other BoB style (Lucky 5.1s are the best IMO) Without that and the rest, it's a headache to own on the field. Yes people can manage, but it's not worth it. How do I know? I own 2 ions myself.
That's also why the Dye Ion and GoG Ion (the Proto Rail and GoG eXTCy) are so much better. They work the same (which was never a bad thing), but already have these exterior problems fixed. They come with good boards, clamping feednecks, etc. (except Proto Rails before '09 had shit triggers and feednecks that broke when over-tightened)
Edited by Lotus, 05 July 2014 - 10:32 PM.
#6 ClayCallison
ClayCallison
    Vatican Assassin Worlock
  • 452 posts
Posted 06 July 2014 - 10:54 PM
I have an Ion and I got it with all the upgrades it needed for a cheap price so for me it was a good deal.  For $150 I got the Ion, a backup gun, gearbag, pod pack, and paintballs.  The Ion has a new trigger, a blackheart board, clamping feedneck, dye ultralight barrel, and dye asa.  If you can find one with all of those upgrades for $50-$100 I would get it.  The shitty retail value is good if you are buying one because you can get it dirt cheap just make sure it has upgrades.
If you're under 18 and pay for your own stuff, put this in your signature.
#7 Curry Pi
Curry Pi
    Black Lightning Thunder Panther
  • 204 posts
Posted 23 July 2014 - 06:19 PM
Ions are dirt cheap on sites like ebay but you can probably find better but it really depends on your budget.
"If you think you will give up, you have already failed."
#8 WiiMint
WiiMint
  • 63 posts
Posted 24 July 2014 - 11:15 AM
Pass... Ions aren't really for me. However, everyone is entitled to their own opinion..
Did you ever notice how Valken Graffiti smells like chocolate? Then, when you leave some in a pod on a hot day, they smell like melted chocolate!
