Dangerous power G5
#1 sambonec
sambonec
  • 11 posts
Posted 10 August 2014 - 11:27 AM
I'm getting a new dangerous power G5. Can you guys please give me some pros and cons about the G5, or recommend a different gun within the same price range.
#2 smurfinator22
smurfinator22
  • 710 posts
Posted 10 August 2014 - 11:38 AM
if i were you i would look at used high end markers. many older model high ends can be found for $350 or less. there are so many choices too when it comes to used high ends too. for example: Used ego 5-9, used dm 3-9, used bob long vices, proteges, marqs, closers, and intimidators. all you have to do is look through the BST here and on other forums and you'll see what I'm talking about.
all of these markers would vastly outperform a g5 for the exact same cost or maybe even less. so seriously consider buying used
#3 Toxin PB
Toxin PB
    California Baller
  • 567 posts
Posted 10 August 2014 - 12:43 PM
Ego 7, axe, vice, etc. A used highendwill outperform the g5 any day.
#4 andrewthewookie
  • 22,429 posts
Posted 10 August 2014 - 01:14 PM
I disagree that a used high end is automatically assumed to outperform the G5. There are many shitty high ends, and many good high ends, just like there are shitty and good low end markers.
The G5 is a quite capable gun, and shouldn't be discounted just because of the price tag.
#5 r45vt
r45vt
  • 557 posts
Posted 10 August 2014 - 07:03 PM
G5 isn't bad.  Like I said in a few other threads just don't run a SHP(super high pressure) HPA tank in you should be fine.  A few people bought SHP tanks that output 1100psi and blew some o-rings.  It can take 850 which is standard no problem.
It's not the most efficient on air but it will well.
My youtube channel:
https://www.youtube....QgnGna7lWBK-c3w
Watch some paint splat on people!
