Need some help fixing my shitty guns
spyder tippmann
18 replies to this topic
#1 ClayCallison
ClayCallison
    Vatican Assassin Worlock
  • 452 posts
Posted 10 August 2014 - 11:22 PM
So today I got a tippmann 98 custom, piranha gti, spyder compact, and viewloader triad with three masks including a vforce profiler and some accessories for $40.  All I wanted was the mask but the guy threw in all of that shit.  I plan on flipping it for money to get new pads.  Right now only the 98 custom works.  The triad is just gunked up from melted o rings and once cleaned will shoot fine.  The gti and the compact however leak like a motherfucker when you screw a tank on.  They leak out of the side of the grips when cocked and if you pull the trigger it leaks down the barrel.  I know it has something to do with the poppet valve but I don't know what.  I replaced the o rings on the rammers and that didn't hep one bit.  Anyone know what I can try?  I live about five minutes from wicked sports in Tampa so I can get parts but I don't want to eat up my profit either.
If you're under 18 and pay for your own stuff, put this in your signature.
#2 AoSpades
AoSpades
  • 1,281 posts
Posted 11 August 2014 - 05:33 AM
sounds like you need orings, orings for days.
Step up your game: Go A.P.E.
#3 Pvlacrosse14
Pvlacrosse14
    Indians Football OG #67
  • 2,637 posts
Posted 11 August 2014 - 09:09 AM
Just a wild guess but if you think it's due to the poppet valve, why not change the orings on the poppet?
#4 martix_agent
martix_agent
  • 12 posts
Posted 11 August 2014 - 09:41 AM
The clone GTI is a spool valve design, is it not? Replace the orings on the bolt and your leaking issues should go away, assuming the regulator is set properly.
If the spyder is leaking out the barrel, replace the poppet. You can even flip the old one around and see if it seals; sometimes you get lucky.
#5 Pvlacrosse14
Pvlacrosse14
  • 2,637 posts
Posted 11 August 2014 - 10:15 AM
I believe he has a piranha gti, not a clone gti
#6 BurningPlaydoh
Posted 11 August 2014 - 12:08 PM
Im so glad you read first sentence of the first post.
#7 ClayCallison
ClayCallison
  • 452 posts
Posted 11 August 2014 - 12:42 PM
Yeah all of the orings were melted into a liquid so the first thing I did was replace them.  I still need a new kit to seal up the gti but the spyder is still a mess.  The poppet isn't damaged I just can't figure out what's wrong with it.
#8 martix_agent
martix_agent
  • 12 posts
Posted 11 August 2014 - 01:02 PM
flip it around and see what happens. It may not appear damaged, but often it is not visible.
#9 ClayCallison
ClayCallison
  • 452 posts
Posted 11 August 2014 - 01:21 PM
What do you mean by flip it around?  You cant do that it's not the same on both sides one side is a rod that fits into the hole and the other is a peg that the spring sits on.
#10 martix_agent
martix_agent
  • 12 posts
Posted 11 August 2014 - 01:59 PM
Ah. Some will work if you flip them around. Yours does not, it seems :(
#11 Pvlacrosse14
Pvlacrosse14
  • 2,637 posts
Posted 11 August 2014 - 02:12 PM
Check the poppet face for lube. If there is ANY lubricant on the poppet face, it will leak. If there are any orings on the poppet shaft, replace them.
#12 ClayCallison
ClayCallison
  • 452 posts
Posted 11 August 2014 - 02:57 PM
Ok I'll try that.
#13 foxx0440
foxx0440
  • 332 posts
Posted 12 August 2014 - 11:36 PM
Sounds like the cup seals are defective
#14 ClayCallison
ClayCallison
  • 452 posts
Posted 13 August 2014 - 12:19 AM
That's exactly what I've come down to as well.  I can't find any visible damage but I guess it's time to get a few new cup seals...
#15 chris92545
chris92545
  • 1 posts
Posted 15 October 2014 - 03:50 PM
Seems like a lot of these dudes don't know what they are talking bout.
#16 ChloricName
ChloricName
    RIP Jared Rice (12/18/14)
  • 1,978 posts
Posted 15 October 2014 - 07:28 PM
first of all, please don't necro. Second of all, what gives you the right to say these people don't know what they are taking about?
#17 agentx
agentx
    The Paintball Pagoda
  • 75 posts
Posted 16 October 2014 - 02:28 PM
Clay,
What kinda pads you looking for? Elbow or Knee or Both?
I just picked up some decent used Planet Eclipse bow and knee pads, they are just a little tight for me. I am looking to build up a new 98 woodsball gun. Just ordered a flatline the other day.
Hmmmmm?
What size do you wear?
Hit me up and let me know. Maybe we could trade out?
Hmmm?
#18 ChloricName
ChloricName
  • 1,978 posts
Posted 16 October 2014 - 04:46 PM
*impersonating Andrew* BST out of BST, you're all banned. If you want to deal do it in the BST forum. That'so why it's there. Also the thread should be dead, let if die. If you want to talk to clay, pm him.
#19 SeanPB1029
SeanPB1029
    R.I.P Bob Gurnsey
  • 632 posts
Posted 30 October 2014 - 09:46 AM
And coming from somebody with 1 post.....
Dye XX Ironmen Edition DM14- GI Grill-Ninja 48/45-Empire Z2
IFyouAREunder18andYOUpayFORyourGEARputTHISinYOURsig
giphy.gifTECH PB HEAVY METAL FAN CLUB  http://www.techpb.co...metal-fan-club/
