Help with my g3
#1 paintballandhockey0120
  • 235 posts
Posted 24 April 2009 - 10:15 PM
ok so i have had my g3 for a little bit now and im consistantly having barrel breaks like once or twice a day what could be the problem
I live in florida its humid could that be a problem?
my barrel is clean and doesnt have scratches inside so thats not it
Edited by paintballandhockey0120, 24 April 2009 - 10:16 PM.
#2 3migo
3migo
    Owl Capone
  • 10,865 posts
Posted 24 April 2009 - 10:18 PM
if its humid, here is what happens: condensation builds up on the inside of the barrel, causing inconsistancy. My suggestion? get a carbon fiber barrel, try the new stiffi barrel, they are only 60 bucks. it will not be affected by the humidity factor, and it will severely cut back on your barrel breaking problem
Chief Night Owl
The Writer of the Prophecy
My Moderator Application
#3 paintballandhockey0120
  • 235 posts
Posted 24 April 2009 - 10:20 PM
is that the only problem or is there other possible
#4 c-town
c-town
  • 494 posts
Posted 24 April 2009 - 10:21 PM
could be ur paint is all swelled or bad idk check ur paint and by the top of the line paint
