Best tank for a forward player.
9 replies to this topic
#1 laburton
laburton
    Full Time Helper
  • 2,312 posts
Posted 16 October 2008 - 08:18 PM
OK i just need some help im buying a new tank and i want to know whats the best tank for a front player other than a 48/45 ...
---------------------------------------------------- If I Have Helped you At All During Your Stay at The TechPB Hotel Click Here
#2 Speedz
Speedz
  • 64 posts
Posted 16 October 2008 - 09:10 PM
Maybe a 45/45? But honestly it's whatever you feel the most comfortable with. It doesn't matter what tank you have if you don't feel comfortable while you're in a shooting position with it.
#3 Heywod
Heywod
  • 861 posts
Posted 16 October 2008 - 09:16 PM
Alot of front players use 45/45s or 48/45s because they are lighter than 68/45s. If you like a 68/45 better than the smaller 45/45s, get a 68/45. It's persional preference.
aim = HeywodJahblomeh
XBL = Heywod
#4 Sikdawg03
Sikdawg03
  • 500 posts
Posted 16 October 2008 - 10:38 PM
A Dye throttle 70/4500, it's stubby and light.
AFFLICTION
#5 adrenilanejunkie
adrenilanejunkie
  • 673 posts
Posted 16 October 2008 - 10:43 PM
try the empire 56/45 i have heard its the best inbetween tank but i have not personally used it
Paintball: is my sport, is my passion, my life.
http://www.techpb.co...=0 Geo Owner
#6 Berto
Berto
  • 309 posts
Posted 16 October 2008 - 10:44 PM
45/45s seem to be the best choice
#7 laburton
laburton
    Full Time Helper
  • 2,312 posts
Posted 17 October 2008 - 03:37 PM
alrite , thanks.
#8 Lucas
Lucas
  • 5,342 posts
Posted 17 October 2008 - 03:44 PM
Go with a 48, unles you want a good around tank and decide to man up get a 68
#9 laburton
laburton
    Full Time Helper
  • 2,312 posts
Posted 20 October 2008 - 05:53 PM
Thanks
#10 backshooterbeast
backshooterbeast
  • 4 posts
Posted 21 October 2008 - 12:06 AM
What is the difference in a $200 hpa tank and a $60 hpa tank if you're using a tippmann or a proto rail?
