Shoebox Shocker, need cockerpunks help
#1 jdlarson11
  • 7,664 posts
Posted 22 August 2009 - 10:44 PM
bought one off ebay, at 220 psi it barely cycles, whats wrong, thanks.
#2 Altec
    We'll Clip Your Nuts!
  • 158 posts
Posted 27 August 2009 - 08:38 PM
I don't know if you are still looking at this thread, but here is a link to Ydna's page on the Shoebox. He is pretty much the Shocker master.
I myself don't know enough to help. Just the design, and history. Not the normal quirks, and such.
"Lesbian Nazi Hookers Abducted by UFOs and Forced Into Weight Loss Programs!"
The Core Scenario Paintball Team
#3 Ice_Chip
    Win..or something.
  • 308 posts
Posted 26 September 2009 - 10:15 AM
Have you taken the gun apart? One weak spot in the shoebox is the firing cylinder. The area with the 4 holes likes to break off after heavy use, and this can prevent cycling. Also, check the blot plunger o-ring. If it's swollen that will prevent full cycling as well.
Firing Cylinder
Edited by Ice_Chip, 26 September 2009 - 10:15 AM.
<img src="http://www.shimonpho...chPB_Sig1B.jpg" border="0" class="linked-sig-image" />
-I had quite possibly the coolest sig on the site, but it got violated by Kitty for being over 30K
