Dangerous Power G3 vs Proto SLG UL 09!!!
#1 squigglezz
squigglezz
  • 24 posts
Posted 27 October 2008 - 11:01 PM
okay here it is guys
i currently own an insanely upped ion but
plan on upgrading to a better gun around christmas time
I say intrigued by the 09 slg and had my head set on that
but dp just lowered the price on the g3 to 300
so, i want to know what the main differences are and your guy's opinoin on what i should get
thanx guys
EDMONTON IMPACT FAN #26
LA INFAMOUS FAN
# 6
I am under 18 and I pay for my own gear.
Sit your ass down.
#2 adrenilanejunkie
adrenilanejunkie
  • 673 posts
Posted 27 October 2008 - 11:46 PM
The g3 is a better quality marker but the ultralite is pretty comfy so i would say g 3
Paintball: is my sport, is my passion, my life.
http://www.techpb.co...=0 Geo Owner
#3 z3th
z3th
  • 102 posts
Posted 28 October 2008 - 06:27 PM
If you already have an upped ion, then it's not really an upgrade going to a G3 or SLG. The next step would be a higher price range like angel a1, bob long marq/vice, pe etek2/ego 08/09, mavdev droid. I'm not saying all those markers are on the same level, but just giving you a better grasp of price range.
But to answer your question more directly, I would pick the SLG just because Dye/Proto have been making markers longer than DP if I'm not mistaken. DP G3 is a great marker as well, and with the price drop it's hard not to try out the marker.
