There is a problem with my Mokal Aura.
#1 lightfoot
lightfoot
  • 145 posts
Posted 29 October 2008 - 05:25 PM
We took it to the field and the gun worked fine at first but the second game the gun was not responding to all the trigger pulls. Any suggestions on how to fix it?
ps. Could not find any thing in the manual that would help.
#2 victoralphacharlie
victoralphacharlie
    Midwest Army
  • 520 posts
Posted 01 November 2008 - 09:20 AM
Try a fresh battery and cleaning the eyes up.
Paradise Storm
Paintball Paradise/ /Guerrilla Air/ /ANSgear/ /Trade My Gun/ /Valken Paintballs
#3 lightfoot
lightfoot
  • 145 posts
Posted 03 November 2008 - 10:51 AM
Thats the basic stuff I did befor I even posted this.
#4 blackstar848
blackstar848
  • 227 posts
Posted 05 November 2008 - 02:43 PM
take out the bolt and striker then totally clean both tubes. once you do that clean the eye's and put a new battery in the gun. inspect the board for any damage and then lube the gun and reinstall it. also put 4-5 drops of gun oil into your gun then air it up and see if it will fire.
#5 Alex Reed
Alex Reed
  • 3 posts
Posted 05 May 2012 - 09:23 AM
if it works fine wen you tern off the eyes then the problem is you have one of the new 2011Auras so the board is defective you need to call the company and tell them what is wrong they will tell you to send the board in and they will update it at least that was the problem with my brothers 2011aura :)
go to mokal.com
